9 years agointeger overflow
Can anyone explain me why ModelSim Intel Starter Edition 10.5b does not complain about integer overflows, i.e. why the following code
process
variable n : integer;
begin
n := 0;
report integer'image(n);
for i in 1 to 1000 loop
n := ((10 * n) + 3);
end loop;
wait;
end process;
generates that: --- Quote Start --- 0 3 33 333 3333 33333 333333 3333333 33333333 333333333 -961633963 -1026405035 -1674115755 438711637 92149077 921490773 624973141 1954764117 -1927195307 -2092083883 553997653 1245009237 -434809515 -53127851 -531278507 -1017817771 -1588243115 1297438037 89478485 894784853 357913941 -715827883 1431655765 1431655765 1431655765 ... --- Quote End --- Thanks, - Julien2 Replies
Interesting - it could possibly be a bug - BUT
It could be that integer implementation in VHDL is tool dependent, and not defined in the VHDL LRM. So you cannot check the range of the 32 bit integer if it goes over 32 bits! Raise a ticket with mentor and see what they say. - Altera_Forum
I can see the very same behavior with Vivado Simulator 2016.4.
If it is not defined in the LRM, then I agree it is not really a bug. Thanks! - J
