12 years ago
Integer as an array.
I am using an integer to count pulses and then need to give it to an 7 Segment display.
Can I use the Integer variable as an array directly , and read each place's value ?
The highlighted statement gives an error.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.all;
entity newcounter is
Port ( clk : in std_logic;
HEX0,HEX2, HEX1: out std_logic_vector(6 downto 0):= "1111110" );
end entity;
architecture Behavioral of newcounter is
signal temp0,temp1,temp2: integer :=0;
begin
process (clk) is
type seven_seg is array ( 0 to 9 ) of std_logic_vector ( 6 downto 0 );
constant decode : seven_seg := ( "1000000" , "1111001" , "0100100" , "0110000" , "0011001" , "0010010" ,
"0000010" , "1111000" , "0000000" , "0010000" );
variable count: integer:=0;
begin
if rising_edge(clk) then count := count + 1;
end if;
temp0 <= count(0);
HEX0 <= decode( temp0);
end process;
end Behavioral;
    no, an integer is not an array, so you cannot do this. And anyway, you could not take an integer from it even if you could - it would be a single bit.
    to get access to the single bits, you need to convert it to an array type - easiest would be signed or unsigned:
    signal temp : std_logic;
    temp <= to_signed(count, 1)(0);
    I get the following error -
    Error (10476): VHDL error at newcounter.vhd(32): type of identifier "temp0" does not agree with its usage as integer type.
    The snippet is
    temp0 <= to_signed(count, 1)(0);
    HEX0 <= decode(temp0);
    with the rest same as above.
    Hi, read/understand the error and look at the code :cool:
    remove temp0 form the line "signal temp0,temp1,temp2: integer :=0;"
    add the line "signal temp : std_logic;" (from Tricky) just under
    And write
    outside the process
    OR write
    process (clk) is
    -- variable declarations
    begin
       count := count + 1;
    end if;
    end process;
    By this last way, you will produce register and then latence : count --> temp0 --> decode
    (outside the "if rising_edge(clk)...end if;", you will get very unexpected results !)
    You need to be more rigorous :-P and get good basis in VHDL (Altera vhdl style guide line....)
