Hi, read/understand the error and look at the code :cool:
remove temp0 form the line "signal
temp0,temp1,temp2: integer :=0;"
add the line "signal temp : std_logic;" (from Tricky) just under
And write
temp <= to_signed(count, 1)(0);
HEX0 <= decode(temp0);
outside the process
OR write
process (clk) is
-- variable declarations
begin
if rising_edge(clk) then
count := count + 1;
temp0 <= to_signed(count, 1)(0);
HEX0 <= decode( temp0);
end if;
end process;
By this last way, you will produce register and then latence : count --> temp0 --> decode
(outside the "if rising_edge(clk)...end if;", you will get very unexpected results !)
You need to be more rigorous :-P and get good basis in VHDL (Altera vhdl style guide line....)
