12 years agoDear Daixiwen,
I appreciate your reply and pointing out. I understand that reset vector must be adjusted by relationship between SOPC builder and Nios EDS automatically. I s there any potential to break this coordination? After my post I found some deference in .objdump file between good case and bad case. In good case, there is following part in the .objdump file. 00002000 is the my reset vector address. ========= 00002000 <__reset>: * Jump to the _start entry point in the .text section if reset code * is allowed or if optimizing for RTL simulation. */ # if defined(ALT_ALLOW_CODE_AT_RESET) || defined(ALT_SIM_OPTIMIZE) /* Jump to the _start entry point in the .text section. */ movhi r1, %hi(_start) 2000: 00400034 movhi at,0 ori r1, r1, %lo(_start) 2004: 08480814 ori at,at,8224 jmp r1 2008: 0800683a jmp at 0000200c <_exit>: ... =============== In bad case, there is not above part. Is it any hint? Tank you.
