Instantiation of the module in a toplevel module
- 3 years ago
When "fifo_0_out_address"=1, readdata take in the channel value but not having opposite endianness check image below:
As this time channel had been being assigned some value.
Check document details:
If the read is valid, that is, the FIFO core is not empty, both data and packet status information are popped from the FIFO core. The packet status information is obtained by reading at address offset 1. Reading from address offset 1 does not pop data from the FIFO core.
Sheng
Thank you very much!
I have noticed that setting the "fifo_0_out_address"=0 in the simulation test bench (\FIFO_TEST\fifo_qsys\sim\fifo_qsys_tb.v) an output data that is having opposite endianness to that of "fifo_0_out_address"=1 . I have a hard time in understanding why this happening. Do you have any thought regarding this?
The screenshot showing the simulation output for setting (simulated using the fifo_qsys_tb.v attached)
#1fifo_0_out_address=0
#10fifo_0_out_address=1
#10fifo_0_out_address=0
is attached Capture_modelsim1.PNG (please see the readdata and fifo_0_out_address signals in the modelsim wave output). I am confused why endian conversion in FIFO core is affected by the avalon mm input signal fifo_0_out_address ?
