Instantiation of the module in a toplevel module
- 3 years ago
When "fifo_0_out_address"=1, readdata take in the channel value but not having opposite endianness check image below:
As this time channel had been being assigned some value.
Check document details:
If the read is valid, that is, the FIFO core is not empty, both data and packet status information are popped from the FIFO core. The packet status information is obtained by reading at address offset 1. Reading from address offset 1 does not pop data from the FIFO core.
Sheng
Check the document:
The FIFO core performs the endian conversion to conform to the output interface protocol.
If Enable packet data is turned off, read data repeatedly at address offset 0 to pop the data from the FIFO core. (At address offset 1 will not pop the data)
Sheng
