8 years agoInstantiation Errors
I'm trying to reference my full adder module inside another module but seem to be getting lost somehow in the referencing. I keep getting the error Checker 'Full_Adder' not found. Instantiation 's' must be of a visible checker. the code I have is: always @(posedge clk) begin if (reset==1) // reset isn't pressed begin if (enable==1) //enable is active begin case ({ALU_OP}) 2'h0 : D = A & B; 2'h1 : D = A | B; 2'h2 : Full_Adder f(A,B,D,C); 2'h3 : D = A * B; endcase end end end endmodule module Full_adder(a,b,answer,carry_out); //inputs input [2:0] a,b; //outputs output [2:0] answer; output carry_out; //wires wire carry_out; wire [2:0] carry; genvar i; generate for(i=0;i<2;i=i+1) begin: generate_N_bit_Adder if(i==0) half_adder f(a[0],b[0],answer[0],carry[0]); else full_adder f(a,b,carry[i-1],answer,carry); end assign carry_out = carry[2]; endgenerate endmodule3 Replies
A module is not like a C function, it is like a chip on a circuit board, so it cannot be "called" inside sequential code. You must instantiate it on its own in parallel to your always block, and then use the sequential code to control the signals connected to it.
Take care on suggested point about instantiation.
etc. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)half_adder f(a,b,answer,carry); full_adder f(a,b,carry,answer,carry); full_adder f(a,b,carry,answer,carry); - Altera_Forum
The issue is the module names. Verilog is case sensitive. In the module you've used "Full_adder" and in the instantiation you've used "Full_Adder" . The tool will think this "Full_Adder " is another module. Just be careful about the module names. Plus as pointed out earlier, instances are not like C functions. Use named instances instead of positional as this will reduce the chances of errors.
