17 years agoHi,
I'm new on VHDL and QUARTUS II. I receive errors from compilation because of 'ELSE' in my code. I don't understand why Quartus II don't recognize ELSE, WAIT FOR , and WHEN . Please help me, I want know. This is one of my code which don't compile successfuly : LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.numeric_std.all; --------------------------- ENTITY compt IS PORT ( C: IN STD_LOGIC; V: IN STD_LOGIC; A: OUT STD_LOGIC ); END compt; --------------------------- ARCHITECTURE arc OF compt IS BEGIN IF (C'EVENT AND C='1' AND V='0') THEN A <= '1'; ELSE A <= '0'; END IF; END arc; Error (10500): VHDL syntax error at compt.vhd(21) near text "IF"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at compt.vhd(21) near text "THEN"; expecting "<=" Error (10500): VHDL syntax error at compt.vhd(23) near text "ELSE"; expecting "end", or "(", or an identifier ("else" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at compt.vhd(25) near text "IF"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture" Really thank you by advance Pascale
