18 years agoLook in the "Processing" tab of the messages screen near the bottom of your QuartusII window (ALT-3 toggles this window on/off). You should see messages relating to the processing of your design including which file is being processed. Make sure it is reading in all of your files, and if not then look for messages stating why.
