14 years agoHere is an example that builds horribly wrong. I expected Table to be split into any kind of memory even without the ramstyle attrib, but fails. It all goes into ALUT's (stratix III, Q10.1sp1 and Q11.0sp1).
I will try to raise my first ER on this case..
--testing the record to mem instanciation
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity record_mem is
port
--write bus
clk1 : in std_logic;
de1 : in std_logic;
adr1 : in std_logic_vector(8 downto 0);
data1 : in std_logic_vector(31 downto 0);
--32bit output from the record array
clk2 : in std_logic;
adr2 : in std_logic_vector(7 downto 0);
data2 : out std_logic_vector(31 downto 0);
--16bit output from the record array
clk3 : in std_logic;
adr3 : in std_logic_vector(7 downto 0);
data3 : out std_logic_vector(15 downto 0);
--8bit output from the record array
clk4 : in std_logic;
adr4 : in std_logic_vector(8 downto 0);
data4 : out std_logic_vector(7 downto 0)
end record_mem;
architecture rtl of record_mem is
type TableEntry is record
record_32bit_at_adr0 : std_logic_vector(31 downto 0);
record_16bit_at_adr1_high_word : std_logic_vector(15 downto 0);
record_8bit_at_adr1_low_word_low_byte : std_logic_vector(7 downto 0);
record_8bit_at_adr1_low_word_high_byte : std_logic_vector(7 downto 0);
end record;
type TableArray is array (integer range 255 downto 0) of TableEntry;
signal Table : TableArray;
alias adr1_wordadr : std_logic_vector(0 downto 0) is adr1(0 downto 0);
alias adr1_memidx : std_logic_vector(7 downto 0) is adr1(adr1'high downto 1);
alias adr4_wordadr : std_logic_vector(0 downto 0) is adr4(0 downto 0);
alias adr4_memidx : std_logic_vector(7 downto 0) is adr4(adr4'high downto 1);
begin
write_dp_mem:process (clk1)
begin
if(rising_edge(clk1)) then
if(de1='1') then
case conv_integer(adr1_wordadr) is
when 0=>
Table(conv_integer(adr1_memidx)).record_32bit_at_adr0 <=data1;
when 1=>
Table(conv_integer(adr1_memidx)).record_16bit_at_adr1_high_word <=data1(31 downto 16);
Table(conv_integer(adr1_memidx)).record_8bit_at_adr1_low_word_low_byte <=data1(7 downto 0);
Table(conv_integer(adr1_memidx)).record_8bit_at_adr1_low_word_high_byte <=data1(15 downto 8);
when others=>
end case;
end if;
end if;
end process;
read_32bit_mem:process (clk2)
begin
if(rising_edge(clk2)) then
data2<=Table(conv_integer(adr2)).record_32bit_at_adr0;
end if;
end process;
read_16bit_mem:process (clk3)
begin
if(rising_edge(clk3)) then
data3<=Table(conv_integer(adr3)).record_16bit_at_adr1_high_word;
end if;
end process;
read_8bit_mem:process (clk4)
begin
if(rising_edge(clk4)) then
if(conv_integer(adr4_wordadr)=0) then
data4<=Table(conv_integer(adr4_memidx)).record_8bit_at_adr1_low_word_low_byte;
else
data4<=Table(conv_integer(adr4_memidx)).record_8bit_at_adr1_low_word_high_byte;
end if;
end if;
end process;
end rtl;
