9 years agoInstalling the Intel FPGA SDK for OpenCL
I have Installed the Intel FPGA SDK for OpenCL as "Intel FPGA SDK for OpenCL Getting Started Guide" said .But I don't clear how to set environment variables .http://www.alteraforum.com/forum/attachme...
9 years agoOn windows you should go to System Properties > Advanced > Environmental Variables, create a new variable with "ALTERAOCLSDKROOT" (without quotes) as its name and the path to your "hld" directory as variable value. Then you should edit the existing PATH variable and add the three values above to the existing values. Though I think the installer might automatically create the "ALTERAOCLSDKROOT" variable but I am not sure.
You can find some examples here: http://www.computerhope.com/issues/ch000549.htm
