MTett1's avatar
MTett1
6 years ago
Installing Quartus Lite 20.1 on Ubuntu 20.04
I am trying to install Quartus Lite 20.1 on my ubuntu 20.04 but then I get this error which I have no idea on how to fix it.
Error: cannot find "/opt/intelFPGA_lite/20.1/modelsim_ase/bin/../linux_x86_64/vsim"
    • MTett1's avatar
      MTett1
      @RichardTanSY_Altera
      I have attached attached the vsim file below which is quite different from the previous versions of Modelsim. For example this `vco="linux_rh60" ` no longer exist in the current ModelSim version.
    • MTett1's avatar
      MTett1
      mode=${MTI_VCO_MODE:-"32"}
      arg0="$0"
      cmd=`basename "$arg0"`
      uname=`uname`
      utype=`uname -r`
      umach=`uname -m`
      case $uname in
      AIX)
      islink=-L
      CYGWIN_NT* | MSYS_NT*)
      islink=-h
      Win*)
      uname=CYGWIN_NT
      islink=-h
      islink=-h
      esac
      while [ $islink "$arg0" ] ; do
      x=`/bin/ls -ld "$arg0"`
      x=`expr "$x" : '.* \(.*\)'`
      case "$x" in
      /*) arg0="$x" ;;
      *) arg0="`dirname ""$arg0""`/$x" ;;
      esac
      done
      dir=`dirname "$arg0"`
      #added
      export LD_LIBRARY_PATH=${dir}/lib32
      vco=${uname}${utype}
      case $vco in
      Linux*)
      # On Linux, default to 32 bit unless MTI_VCO_MODE is set
      # except for Visualizer where we invoke 64-bit version by default
      if [ "$mode" = "" ] ; then
      if ( [ "$cmd" = "visualizer" -o "$cmd" = "vis" ]) \
      && ( [ -x "$dir/linux_x86_64/visualizer" ] ) ; then
      mode="64";
      elif ( [ -x "$dir/linux/vsim" -o -x "$dir/linuxpe/vsim" ] ) \
      && ( [ "$umach" != "aarch64" ] ); then
      mode="32";
      fi
      fi
      # If IA-64 or X86-64 architecture and machine-specific vsim is not
      # installed but linux vsim is available, use linux platform.
      # Otherwise use machine-specific platform.
      if [ "$mode" != "32" ] \
      && ( [ "$umach" = "ia64" ] \
      || [ "$umach" = "x86_64" ] \
      || [ "$umach" = "aarch64" ] ) \
      && ( [ "$mode" = "64" ] \
      || [ -x "$dir/linux_$umach/vsim" ] \
      || [ ! -x "$dir/linux/vsim" ] ) ; then
      vco="linux_$umach"
      else
      vco="linux"
      if [ ! -x "$dir/$vco/vsim" -a -x "$dir/linuxpe/vsim" ]; then
      vco="linuxpe"
      fi
      fi
      if [ -x "$dir/win32/vsim" ]; then
      vco="win32"
      elif [ -x "$dir/win32pe/vsim" ]; then
      vco="win32pe"
      fi
      if [ "$mode" = "" ] ||
      [ "$mode" = "64" ] ; then
      sysostype="`systeminfo 2>&1 | grep -i 'System Type' | cut -f1 -d- | sed s@x@X@ | cut -f2 -dX`"
      if [ "$sysostype" == "64" ] ; then
      vco="win64"
      fi
      fi
      vco="unknown"
      esac
      doatenv=0
      case $cmd in
      qhdir)
      cmd=vdir
      qhmap)
      cmd=vmap
      qvlcom)
      cmd=vlog
      qhlib)
      cmd=vlib
      qhsim)
      cmd=vsim
      qhdel)
      cmd=vdel
      qhmake)
      cmd=vmake
      qvhcom)
      cmd=vcom
      qhgencomp)
      cmd=vgencomp
      vco)
      echo $vco
      exit
      hdloffice)
      doatenv=1
      hdlstudio)
      doatenv=1
      esac
      # verify that we can find the command to execute.
      if [ -x "$dir/$vco/$cmd" ] ; then
      arg0="$dir/$vco/$cmd"
      else
      # if bin nolonger has symbolic links in it then
      # we need to look up and over
      f2="$dir/$vco/$cmd"
      if [ -x "$f2" ] ; then
      arg0="$f2"
      elif [ -x "$dir/${vco}pe/$cmd" ] ; then
      arg0="$dir/${vco}pe/$cmd"
      elif [ -x "$dir/${vco}le/$cmd" ] ; then
      arg0="$dir/${vco}le/$cmd"
      else
      # Last ditch effort. Use original arg0 and try it!
      d2=`dirname "$0"`
      f2="$d2/$vco/$cmd"
      if [ -x $f2 ] ; then
      arg0=$f2
      else
      echo "Error: cannot find \"$dir/$vco/$cmd\""
      exit 1
      fi
      fi
      fi
      if [ $doatenv ]; then
      if [ -x "$dir/$vco/athdlenv" ] ; then
      #. $dir/$vco/athdlenv
      if [ -z "$LD_LIBRARY_PATH" ]; then
      export LD_LIBRARY_PATH="$dir/$vco"
      else
      export LD_LIBRARY_PATH="$dir/$vco:$LD_LIBRARY_PATH"
      fi
      #echo LD_LIBRARY_PATH=$LD_LIBRARY_PATH
      fi
      fi
      if [ -z "$*" ] ; then
      exec "$arg0"
      else
      exec "$arg0" "$@"
  • Hi,
    We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
    Shyan Yew
  • Hi @MTett1,
    I was able to workaround this issue exporting the following environmental variable:
    export MTI_VCO_MODE=32
    The problem seems to be that Modelsim detects that Ubuntu is a x64 OS, but the installer Modelsim Intel Starter Edition only can run in 32 bits mode.
    Exporting that variable to your environment will make Modelsim to be executed in 32 bits regarding the OS architecture.
