12 years ago --- Quote Start --- Upon attempt to get Quartus 13.0 to work, it doesn't seem to want to install correctly in Ubuntu 13.04. --- Quote End --- I'm able to synthetise my project, but to connect to my board. I'm having problems. doing the necessary udev changes and starting jtagd as root, I'm able to find my altera board using jtagconfig. But as soon as I try to download my bitstream to my altera, It looses the connection and aborts the process. After that if I run again ./jtagconfig I cannot see the board anymore. However, if i plug-out the board and plug-in again, running jtagconfig gives me the right output. If I try one more time to download the bitstream, the same problem happens again.. anyone with the same problem? regards
