9 years agoInstalling OpenCL RTE on Cyclone V board
Hi there, I am trying to install the OpenCL RTE version 16.1 on a Cyclone V board. However I realized that there is not a pre-compiled driver to be able to load during the initialization,...
9 years agoHi christnp!
You were correct, it was an issue of not having the 32bits libraries... I solved it by:sudo apt-get install lib32z1 lib32ncurses5
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install libX11-6:i386 libext6:i386 libxft2:i386 libstdc++6:i386 It may be worth nothing that after that we need to configure/prepare the kernel. We need to make sure the cross-compiling env variables are set for this too:
export ARCH=arm
export CROSS_COMPILE=arm-linux-gnueabihf-
cd linux-socfpga
make oldconfig && make prepare
# Here make will ask a bunch of questions, for which I am leaving everything as default.
# Perhaps here lies my issue...
After this I go up one folder and try to compile the driver but I get stuck with the following error:
/c5soc/driver/aclsoc.c: In function ‘free_map_info’:
c5soc/driver/aclsoc.c:364:5: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 3 has type ‘dma_addr_t’
ACL_DEBUG (KERN_DEBUG "free_map_info on vaddr %p, dma 0x%x\n", info->cpu_addr, info->dma_handle);
cc1: some warnings being treated as errors
scripts/Makefile.build:290: recipe for target '/c5soc/driver/aclsoc.o' failed
make: *** Error 1
Makefile:1482: recipe for target '_module_/c5soc/driver' failed
make: *** Error 2 I am also multiplexing/distracted with other things but post here if you have any further suggestions. Many thanks indeed :)!
