17 years ago
Install Quartus8,0 SP1 on Ubuntu 8.04 Hardy Heron
I received segmentation faults constantly while running Quartus8.0 without a Service Pack on Ubuntu 8.04 Hardy Heron on a 32 bit computer. The solution to this, according to Altera is installing the service pack.
The service pack has two tar.gz files in it.
ippatch.gz
qpatch.gz
A tools/ directory containing binaries for
gtar
gzip
compare
A script to install
install_patch
The service pack complains about not being able to gzip -d
Manually too, I cannot gunzip these patch files
In both cases, it complains of a crc error.
Right away it seems that the download may be faulty, but I downloaded the service pack several times to try this. It is definitely not a download issue.
The same files can be gunzipped on an Ubuntu 8.04 64 bit installation.
Has anybody come across this problem and installed SP1 successfully?
    My solution:
    Share the directory, Mount it on 64 bit machine, Install patch using 64 bit machine.
    [Inherently deal with various permission issues]
    # On 32-bit computer
    Change permissions to give 777 for /quartus
    sudo ./nautilus to start nautilus as root
    Right click on directory and open 'Sharing Options'
    Enter a share name, and check allow people to write to this folder
    # On 64 bit computer
    Locate the shared directory
    Mount it using smbmount
    In the script modify :
    the gtar command to just run off /bin and not the tools folder
    Replace gtar xof - with gtar xof - --no-same-owner
    Then run the script
    This worked for me. Long drawn solution. Stayed up till insane hours figuring this out.
    Kind of long drawn - but it seemed to be the only way.
    I would love to hear how somebody did this another way.
    now I have the "Segmentation fault (core dumped)" wrong on the fedora 12.
    how?
