14 years agoI've eventually managed to work around this problem as follows.
- Complete the failed installation as above. This leaves you with a non-functioning installation (indeed Quartus will try to start at the end of the process, and die horribly).
- Go to the main install directory (d:\altera\11.0 in my case) and manually unpack any .z7 files that are left there using 7-Zip file manager. (Delete the final element off the offered path, ie use d:\altera\11.0 as the path to which to extract the files)
- Fix the installation by going to the new Altera entry in the start menu and selecting Modify Altera Complete Design Suite (probably the only entry)
- select the items you wanted installed and re-run the install.
- this time it will complete correctly.
