12 years agoHmmm, Code, you want code. OK here is all I can give you:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8595 As I see it NOW: The three wires which are leading down from the ABZ-Wires, goto some counters, which are counting the POSITIVE EDGES of the Signals. MEA CULPA This is why Quartus thinks these are clocks. OK, in this case I have to change the counters to sample the Inputs and counting a change in a 2Bit shift-register. Sometimes speaking about a Problem helps also to solve the Problem. Thanks
