12 years agoOne other additional piece of information .. the error seems to appear only when I use "SERIES 50 OHM WITH CALIBRATION". If I just use "SERIES 50 OHM" termination, then I do not get any errors and everything works properly.
So it seems something in the /db or /incremental_db folders that is generated from an archive using 13.0.1 is not correct with "SERIES 50 OHM WITH CALIBRATION". Jodi
