10 years agoinout wire logic, quartus15.1, error
Using Quartus 15.1 I have the following issue, when I'm using this construction - inout wire logic [31:0] SIG1; - it is working correctly, but when I define logic [31:0] in typedef into ...
10 years agoLet's view below code, while inout wire logic defines directly it works correctly, but when I try to use logic whithout wire - I get error from Quartus -
Error (10663): Verilog HDL Port Connection error at tst_package.sv(35): output or inout port "SIG1" must be connected to a structural net expression
package state_type;
typedef logic SIG1_WIDTH_T;
endpackage
import state_type::*; // import package definitions into $unit
module inner_m(
input EN,
input SIG1_WIDTH_T IN1,
output SIG1_WIDTH_T OUT1,
inout SIG1_WIDTH_T SIG1//not working
//inout wire logic SIG1//working correctly
assign SIG1 = EN ? IN1 : 'z;
assign OUT1 = SIG1;
endmodule
module tst_sv(
input EN,
inner_m inner_m(
.EN (EN),
.IN1 (IN1),
.OUT1 (OUT1),
.SIG1 (SIG1)
endmodule
