8 years agoInout pin Warning
Hi, I am using Quartus version 17.1. I am receiving this warning message: Warning (12620): Input port OE of I/O output buffer "fx3_dq[1]~output" is not connected, but the atom is driving a...
8 years agoI am using Quartus Prime Standard Edition
fx3_dq is directly connected to FPGA pins, but is also passed into a module like so: fx3 fx3_inst( .reset(reset) ,.clk(clk) ,.fdata(fx3_dq) ,.sloe(fx3_sloe_n) ..... ); This is just an example and inside the module there is an assign like so for fdata: assign fdata = (slwr_loopback_1d_) ? 8'dz : data_from_hps; The code is the sample project from FX3; I'm not sure if I can post it but I have a link to the page. http://www.cypress.com/documentation/application-notes/an65974-designing-ez-usb-fx3-slave-fifo-interface On my top level do I also need a tri-state as mentioned? Or should the tri-state be taken care of with the assign statement in the module? Thank you
