8 years agoInferring ROM for MAX 10 FPGA
Hi All,
I am trying to get Quartus Prime Lite to infer a ROM using the on chip memory (M9K) for MAX 10 FPGA. Instead the ROM gets implemented using LEs which significantly blows up my resource utilisation. I am using the VHDL template in Quartus Edit - Insert Template - VHDL - Full Designs - RAMs and ROMs - Single-Port ROM I have also tried adding the romstyle attribute, but no luck. As an experiment, I changed the device to Cyclone IV and the ROM gets successfully implemented in on chip memory. I have searched online and a I came across a solution using MIF files - https://alteraforum.com/forum/showthread.php?t=54407 However, this solution is too inflexible for me. I'd like to use VHDL rather than the tool's IP wizard. Wondering if anyone has a solution for me? This is driving me crazy. The same VHDL also gets successfully mapped to BRAM on Xilinx devices. Is this a bug in Quartus Prime for MAX 10 FPGAs? Regards, Singh2 Replies
A possible reason that you are using a "compact" MAX10 type that doesn't provide RAM initialization, e.g. SC type. Which device are you compiling the design for?
Hi FvM,
Thanks for your reply. It's 10M16SAU169C8G Regards, Singh
