Geert
5 years agoInference of DSP block with accumulator does not work
I'm trying to infer a DSP block with accumulator for Arria 10, using Quartus Prime 17.0.
The high-level functionality I need is:
if rising_edge(clk) then
if sload = '1' then
out <= a * ...
SengKok_L_Intel
5 years agoHi Greet,
If you are using an independent multiplier, could you please increase the input data width to >19 bits? If using lower than 18 bits, it will not fit into the hard accumulator.
Regards -SK Lim
Geert
5 years agoHi,
Thanks for your answer.
I have tried with multiple different input sizes and indeed, 2x 16-bit multiplier inputs fails (accumulator is implemented in LUTs) , while with a 16-bit + a 24-bit input, I got the expected implementation (hard accumulator).
Could you explain what the exact criterion is? Is it the multiplier result that needs to have a minimal width, or is it just sufficient that one of the multiplier inputs is > 18 bits?
regards,
Geert
