12 years ago
Induced delay
I have just started learning how to use VHDL and Quartus and I use it for a Cyclone II FPGA.
I need to write a code , which makes my Output High after a fixed time interval , 60 seconds for example.
Thus I wrote the following code for the same, however it gives me a warning that my Output pins are stuck at VCC and therefore the the Output ( an LED ) , which is ideally supposed to be OFF and glow only after 60 seconds, is always ON.
I also tried using a wait for 60 seconds statement, however that gives me a Wait statement error, saying that at WAIT UNTIL is required.
The code is
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.all;
entity timer is
port ( q : buffer bit := '0');
end entity;
architecture behaviour of timer is
begin
q <= '1' after 60 sec;
end behaviour;
