10 years agoIncremental Compilation and SignalTap
Hi all, My understanding is that we cannot preserve the placement & routing if we create a new partition under the top-level design (which is a partition by default). In this case, how does the...
10 years agoThanks for the input, Rysc. Too bad most of the time I need to preserve then entire P&R of the design while adding STP as I am dealing with some users' timing constraints. Just trying my luck to see if there is any other solution for this besides setting the top partition to post-fit which usually results in fitting error, and it seems the answer is no.
