10 years agoIncremental Compilation and SignalTap
Hi all, My understanding is that we cannot preserve the placement & routing if we create a new partition under the top-level design (which is a partition by default). In this case, how does the...
10 years agoI was referring to normal devices ( I wasnt aware Arria10 is not able to preserve its routing). That leads me to another question, in order to preserve the P&R of entire design, do I need to also set the other sub-partitions to PostFit or only the Top to Postfit + other partitions under it to SourceFile will just work fine?
Besides source files, what other changes will break the post-fit preservation? I believe SDC file changes will. How about fitter settings (i.e seed sweep, routing/placement effort, physical synthesis). Which will take precedence?
