17 years ago
incorrect path to shell??
Hello, I am new to the Altera environment.
I have the Terasic DE1 development board and have been trying to
build and download to it for some time. I have yet to be able to build both a fpga image (with NIOS) and a NIOS application.
My current problem is with SOPC builder. It fails.
I should note that I have just recently upgraded to 9.0 web tools.
I am running on Windows Vista.
Here is the error output that I am getting when trying to generate.
Info: Wrote C:/altera/90/nios2eds/examples/verilog/DE1_NIOS/low_cost/system_0.sopcinfo
Info: system_0: Wrote C:\altera\90\nios2eds\examples\verilog\DE1_NIOS\low_cost/system_0.html
Info: system_0: Generating QIP file.
Info: Info: *******************************************************************
Info: Info: Running Quartus II Shell
Info: Version 9.0 Build 132 02/25/2009 SJ Web Edition
Info: Info: Processing started: Sat Mar 21 12:20:41 2009
Info: Info: Command: quartus_sh -t sopc_add_qip_file.tcl
Info: Info: Evaluation of Tcl script sopc_add_qip_file.tcl was successful
Info: Info: Quartus II Shell was successful. 0 errors, 0 warnings
Info: Info: Peak virtual memory: 82 megabytes
Info: Info: Processing ended: Sat Mar 21 12:20:42 2009
Info: Info: Elapsed time: 00:00:01
Info: Info: Total CPU time (on all processors): 00:00:01
Info: Starting PTF file elaboration.
/cygdrive/c/altera/90/quartus/bin/cygwin/bin/sh: C:/altera/90/quartus/sopc_builder/bin/sopc_builder: /bin/sh: bad interpreter: No such file or directory
Error: Failed to refresh PTF file
Info: Finished elaborating PTF file.
Executing: C:/altera/90/quartus//sopc_builder/bin/sopc_builder --classic --generate C:/altera/90/nios2eds/examples/verilog/DE1_NIOS/low_cost/system_0.ptf
Info: Starting generation...
Error: System generation failed.
It looks to me that the shell environment variable is set to "/bin/sh". I beleive this to be incorrect. There is no sh at that location. Shouldn't it be set to "/cygdrive/c/altera/90/quartus/bin/cygwin/bin/sh"? If so how do I set it?
I will appreciate any help provided.
