10 years agoInconsitency detected by ld.so
Hello I have a problem with the offline compiler on Ubuntu (unsupported, I know). The compiler runs fine until a inconsistency detected error stops the program. It does not matter whether I use the ...
10 years agoI just had the same alert on the command line as in the first line of your quoted code, except that the number was 811 rather than 762 and the problem occurred with the Quartus Prime Lite installation, but I had no error notice. The installation (on Ubuntu 16.04) finished successfully and the Quartus window happily popped up. The only minor inconvenience I can see is that I had selected the "Create desktop shortcut links" option at the end of the installation process, yet no shortcuts were created---maybe because the desktop directory is named Scrivania in my localized Ubuntu setup?
P.S. I ran the ./setup.sh with root privileges. --- Quote Start --- Hello I have a problem with the offline compiler on Ubuntu (unsupported, I know). The compiler runs fine until a inconsistency detected error stops the program. It does not matter whether I use the high-effort flag or not. Previous problems with this were in Eclipse and could be solved using an update. I haven't seen one for this problem yet. Has anyone encountered this before, and do you know a fix or workaround? The full error is:Inconsistency detected by ls.se: dll-close.c 762: _dl_close: Assertion 'map->l_init_called' failed
Error: Compiler Error, not able to generate hardware. --- Quote End ---
