10 years agoInconsitency detected by ld.so
Hello I have a problem with the offline compiler on Ubuntu (unsupported, I know). The compiler runs fine until a inconsistency detected error stops the program. It does not matter whether I use the ...
10 years agoI have similar problem while compiling opencl example vector_add
2016.06.03.10:06:25 Info: kernel_system: "Generating: kernel_system_channel_adapter_151_jkalxuy"
2016.06.03.10:06:25 Info: kernel_system: "Generating: altera_merlin_master_translator"
2016.06.03.10:06:25 Info: kernel_system: "Generating: altera_merlin_slave_translator"
2016.06.03.10:06:25 Info: kernel_system: Done "<b>kernel_system</b>" with 16 modules, 67 files
2016.06.03.10:06:25 Info: qsys-generate succeeded.
2016.06.03.10:06:25 Info: Finished: <b>Create HDL design files for synthesis</b>
Inconsistency detected by ld.so: dl-close.c: 759: _dl_close: Assertion `map->l_init_called' failed!
Performance warning: Async animation disabled because frame size (13608, 314) is bigger than the viewport (2160, 1109) or the visual rectangle (13608, 314) is larger than the max allowable value (17895698)
