Altera_ForumHonored Contributor14 years agoincluding a MS Visual DLL in a NIOS Project. Hi all, I've a MS visual studion dll wich i want to include in my nios IDE project. in the dll there are somme function, which i would like to use. is this possible? if yes, ...Show More
Altera_ForumHonored Contributor14 years agoIf you have the original source code you could try and port it to the Nios platform.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
