11 years agoRight. I should have thought a bit longer about that. Altera used to ignore the 'library' other than 'work' at that time, several years back and I just adapted. But you remind me now that indeed specifying the Qsys generated component by using "ip: entity.work.system" doesn't work either ... and I then just copied the example HDL component over ...
Thanks for the tip. Regards, Josy
