Altera_ForumHonored Contributor14 years agoIn the mire of timing constraint :mad:Hi, I'm a newbie. And I am in a very annoying situation where I kept adding time constraint to my design and after i recompile, new timing violations popped up. Now my sdc file is loo...Show More
Altera_ForumHonored Contributor14 years agoAdding constraints before is important rather than doing it on the back end.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
