Rahul92
3 years agoIn-system memory content editor - No instances found!!
Hi All,
I am using Quartus prime pro 20.2 version to debug my ROM content. I don't see any ROM instances in my design. I have done the following so far:
1. Create On Chip Memory block using the...
- 3 years ago
Tested with Stratix 10 TX and able to see the instance in ISMCE. Check the file and image attached. Does the FPGA being programmed properly?
Sheng
Rahul92
3 years agoHi Sheng,
Thanks for the files and the screenshot. I did another run and I see the instance now just like your picture.
But, I do have a question. Is it normal to have "Instance ID" as None, even though I give the name as "CM33" while configuring the ROM IP ? I was expecting CM33 as Instance ID instead of None.
Rahul
ShengN_altera
3 years agoHi,
FYI. Please stick with the workaround below in the mean time:
- Go to <Quartus_installed_directory>\ip\altera\sld\jtag\intel_mce\intel_mce_hw.tcl
- Change NODE_NAME type from NATURAL to STRING like the following: add_parameter NODE_NAME STRING 0
- Regenerate related IP and program.
Sheng
