In-system memory content editor - No instances found!!
- 3 years ago
Tested with Stratix 10 TX and able to see the instance in ISMCE. Check the file and image attached. Does the FPGA being programmed properly?
Sheng
Sheng
Hi Sheng,
Thanks for the files and the screenshot. I did another run and I see the instance now just like your picture.
But, I do have a question. Is it normal to have "Instance ID" as None, even though I give the name as "CM33" while configuring the ROM IP ? I was expecting CM33 as Instance ID instead of None.
Rahul
- ShengN_altera3 years ago
FYI. Please stick with the workaround below in the mean time:
- Go to <Quartus_installed_directory>\ip\altera\sld\jtag\intel_mce\intel_mce_hw.tcl
- Change NODE_NAME type from NATURAL to STRING like the following: add_parameter NODE_NAME STRING 0
- Regenerate related IP and program.
Sheng
