9 years agoimporting pin assignments
Hi , I am using Quartus Prime ver 16.0 lite edition , i tried to import pin assignments for my DE2-115 board from a excel file "DE2_115_pin_assignments.csv" , compiled the project but i noticed...
9 years agoI can't help much without seeing the script, but as far as the Pin Planner is concerned, try closing your project and trashing the db folder. Then reopen your project and go back into the Pin Planner to try to make manual assignments again.
As far as the .csv file is concerned, I'd have to see the format you have in the file. If the format is not correct, you won't be able to use it for import.
