implicit declaration of function ‘send_sig_info’ error
I am a student. I want to use OPenCL to write code for my FPGA. I installed FPGA SDK standard edition 17.1 in Ubuntu 16.04. After that I installed intel fpga runtime environment for opencl linux x86-64. After sourcing the script init_opencl.s, I was able to verify my installation using 'aocl version' command. After that I tried to install an FPGA board. So I tried the command 'aocl install' command. It stopped with an error saying/tmp/opencl_driver_tf7ebm/aclpci.c:343:17: error: implicit declaration of function ‘send_sig_info’ [-werror=implicit-function-declaration] int ret = send_sig_info(aclpci->signal_number, &aclpci->signal_info, aclpci-Complete output of the command:
/media/deepak/82d940f9-6526-47c8-8053-79204d78529f/deepak/intelFPGA/17.1/aclrte-linux64/board/a10_ref? y
aocl install: Running install from /media/deepak/82d940f9-6526-47c8-8053-79204d78529f/deepak/intelFPGA/17.1/aclrte-linux64/board/a10_ref/linux64/libexec
/media/deepak/82d940f9-6526-47c8-8053-79204d78529f/deepak/intelFPGA/17.1/aclrte-linux64/board/a10_ref/linux64/libexec/install: 9: /tmp/opencl_driver_tF7ebM/aclpci_queue.o
CC /tmp/opencl_driver_tF7ebM/aclpci.o
/tmp/opencl_driver_tF7ebM/aclpci.c: In function ‘aclpci_irq’:
/tmp/opencl_driver_tF7ebM/aclpci.c:343:17: error: implicit declaration of function ‘send_sig_info’
cc1: some warnings being treated as errors
scripts/Makefile.build:308: recipe for target '/tmp/opencl_driver_tF7ebM/aclpci.o' failed
make: *** Error 1
Makefile:1550: recipe for target '_module_/tmp/opencl_driver_tF7ebM' failed
make: *** Error 2
make: Leaving directory '/usr/src/linux-headers-4.13.0-36-generic'
aocl install: failed.
deepak@deepak:deepak$ aocl install
Help me out. Regards Deepak6 Replies
- EBozo
This happened to me and my solution is
Add #include <linux/sched/signal.h> to the aclpci.h file.
The location of the prototype, send_sig_info, changed, which is not in linux/sched.hanymore for the newer kernel, so that it failed to compile.
Ubuntu is not officially supported by the Intel FPGA SDK for OpenCL, and even though kernel compilation might work correct, the PCI-E driver likely won't (as is your case):
http://dl.altera.com/requirements/17.1/ I recommend using a supported operating system. If you insist on using Ubuntu, you can take a look at this thread and see if the provided solution works for you: http://www.alteraforum.com/forum/showthread.php?t=56568 - Altera_Forum
Thanks. I have now installed it in Windows 10. But the problem now is that aoc command is compiling a hello world program for DE2 board for 2.5 hours.
The command I used: aoc device\hello_world.cl -o bin\hello_world.aocx --board de5net_a7 hello_world.aocx content: // AOC kernel demonstrating device-side printf call __kernel void hello_world(int thread_id_from_which_to_print_message) { // Get index of the work item unsigned thread_id = get_global_id(0); if(thread_id == thread_id_from_which_to_print_message) { printf("Thread# %u: Hello from Altera's OpenCL Compiler!\n", thread_id); } } The following is message after executing the above command: Warning: Please use -board=<value> instead of --board <value> aoc: Running OpenCL parser.... aoc: Optimizing and doing static analysis of code... Compiling for FPGA. This process may take a long time, please be patient. Still the compilation has not stopped. - Altera_Forum
Depending on the characteristics of your machine (CPU speed, memory size, etc.) the compilation could take multiple hours.
Okay I understand. The reason why asked is that the kernel code looks simple and yet it took lot of time. That is why I asked. Thanks anyway
- JMilt1
EBozo's fix also worked for me - thanks! Much better than Altera's response of 'Ubuntu not supported' 🙂
