8 years agoimplicit declaration of function ‘send_sig_info’ error
Hi, I am a student. I want to use OPenCL to write code for my FPGA. I installed FPGA SDK standard edition 17.1 in Ubuntu 16.04. After that I installed intel fpga runtime environment for opencl ...
8 years agoUbuntu is not officially supported by the Intel FPGA SDK for OpenCL, and even though kernel compilation might work correct, the PCI-E driver likely won't (as is your case):
http://dl.altera.com/requirements/17.1/ I recommend using a supported operating system. If you insist on using Ubuntu, you can take a look at this thread and see if the provided solution works for you: http://www.alteraforum.com/forum/showthread.php?t=56568
