12 years ago --- Quote Start --- Can you outline your requirements and we can try to advise on the details. What clock are you using? How many times do you need the input to bounce? Is each bounce the same period (or do they vary)? How do you define the periods? Nial --- Quote End --- I was just told a 10Mhz Clock is what they want to use. The input bounce will be anywhere from 0 to 10 bounces. Each with the same period. Periods are defined by user input... I'm assuming it will be in time in units of ms.
