12 years ago --- Quote Start --- This is something that is going into an actual test bench and talking to other subsystems via a C# application. I don't know what my clock speed is nor how long I should wait. I do realize thought that ns is overkill in trying to simulate the bounce / jitter of a relay switch when it flips. I'm thinking ms should be sufficient. --- Quote End --- Can you outline your requirements and we can try to advise on the details. What clock are you using? How many times do you need the input to bounce? Is each bounce the same period (or do they vary)? How do you define the periods? Nial
