12 years ago --- Quote Start --- So I'm looking at an example from a website called VHDL Guru and they have an example of a 4-bit Johnson counter, but I'm not sure of is how many bits should be sufficient for a counter to gauge time duration? I was told that the range of time I may want to consider would be 0.1 to 10ms. --- Quote End --- I'd never heard of a Johnston counter but a quick google shows it's just a massive shift register. If you've a 10MHz clock you'll need ~ 100,000 bits in your counter for 10ms. Why not just use a 17 bit binary counter to trigger transitions? Nial
