14 years ago
implementing primitives
I am new to vhdl; I tried to instantiate a dff
I put the following at the top:
library altera;
Use altera.altera_primitives_components.all;
and then in the architecture I put the following
xxx : dff
Port map(
d => Phases_in(1),
clk => Clock,
clrn => Reset,
prn => '1',
q => Phases(0)
I get this error
Error (10500): VHDL syntax error at Position_Encoder.vhd(121) near text "Port"; expecting "(", or "'", or "."
It is like it doesn't recognize it as an instantiation. I am using the web edition, is important.
jtg
    You've only posted a snippet, not line 121. This will just be a syntax error.
    line 121 is the one which has "port map" on it.
    If I remove the dffs from the code it compiles fine.
    Library IEEE;
    Use IEEE.std_logic_1164.all;
    Use IEEE.numeric_std.all;
    library altera;
    ENTITY Position_Encoder IS
    Port (
    Reset: IN STD_LOGIC;
    Index: IN STD_LOGIC;
    Home : IN STD_LOGIC;
    Clock: IN STD_LOGIC;
    Phases_in: IN STD_LOGIC_VECTOR (1 downto 0);
    Position: OUT INTEGER RANGE 0 to 500000;
    Present_state: Out std_logic_vector (2 downto 0);
    Error: BUFFER STD_LOGIC
    END Position_Encoder;
    ARCHITECTURE logic OF Position_Encoder IS
    TYPE State IS (state00, state01, state10, state11);
    SIGNAL pr_state, next_state : State;
    SIGNAL temp : integer range 0 to 500000;
    Signal Phases : std_logic_vector (1 downto 0);
    BEGIN
    PROCESS (Reset, Clock)
    BEGIN
    IF (Reset = '1')THEN
    pr_state <= state00;
    temp <= 10;
    ELSIF (Clock'EVENT AND Clock = '1') THEN
    CASE pr_state IS
    WHEN state00 =>
    Present_state <= "000";
    IF (Phases = "00") THEN
    Error <= '0';
    ELSIF (Phases = "10") THEN
    pr_state <= state10;
    temp <= temp - 1;
    Error <= '0';
    ElsIF (Phases = "01") THEN
    pr_state <= state01;
    temp <= temp + 1;
    Error <= '0';
    ELSIF (Phases = "11") THEN
    -- Error <= '1';
    END IF;
    WHEN state01 =>
    Present_state <= "001";
    Error <= '0';
    ELSIF (Phases = "00") THEN
    temp <= temp - 1;
    -- Error <= '0';
    ElsIF (Phases = "11") THEN
    pr_state <= state11;
    temp <= temp + 1;
    Error <= '0';
    Error <= '1';
    END IF;
    WHEN state10 =>
    Present_state <= "010";
    Error <= '0';
    temp <= temp - 1;
    Error <= '0';
    ElsIF (Phases = "00") THEN
    temp <= temp + 1;
    Error <= '0';
    ELSIF (Phases = "01") THEN
    Error <= '1';
    END IF;
    WHEN state11 =>
    Present_state <= "011";
    Error <= '0';
    Error <= '0';
    temp <= temp - 1;
    ElsIF (Phases = "10") THEN
    temp <= temp + 1;
    Error <= '0';
    Error <= '1';
    END IF;
    END CASE; --end: CASE pr_state IS
    --temp <= temp + 1;
    Position <= temp;
    END IF; --end: ELSIF (Clock'EVENT AND Clock = '1') THEN
    xxx : dff
    Port map(
    d => Phases_in(1),
    clk => Clock,
    clrn => Reset,
    prn => '1',
    q => Phases(0)
    delay_2 : dff
    port map (
    d => Phases_in(1),
    clk => Clock,
    clrn => Reset,
    prn => '1',
    q => Phases(1)
    end process;
    END logic;
    Here it is. I appreciate your taking a look.
    you cant instantiate anything inside a process. Instantiation has to be done outside a process.
    Thanks alot. I appreciate your help. Life is good ... well better now.
    jtg
