Hi @CFabr1
If I understand your question correctly, you would like to convert the schematic file into HDL Design file?
Do you able to open the schematic file in Quartus? If so, Go to File–>Create/Update–>Create HDL Design File… and choose the file type (Verilog/VHDL) that you would like to convert to.
Richard Tan
I' trying to translate into Verilog some PAL/GAL devices.I have done this with combinatorial logics but now I'm stuck because I'm dealing with sequential logics.Here's the disassembling of a registered PAL which I want to port in Verilog, you can see there are four regitsered outputs (with clock and OE)
/** Inputs **/
Pin 2 = i2;
Pin 3 = i3;
Pin 4 = i4;
Pin 5 = i5;
Pin 6 = i6;
Pin 7 = i7;
Pin 8 = i8;
Pin 9 = i9;
Pin 12 = i12;
Pin 13 = i13;
Pin 14 = i14;
Pin 15 = i15;
Pin 16 = i16;
Pin 17 = i17;
Pin 18 = i18;
Pin 19 = i19;
/** Outputs **/
Pin 12 = o12; /**(Combinatorial, Output feedback output, Active low) **/
Pin 13 = o13; /**(Combinatorial, Output feedback output, Active low) **/
Pin 14 = o14; /**(Registered, Output feedback registered, Active low) **/
Pin 15 = o15; /**(Registered, Output feedback registered, Active low) **/
Pin 16 = o16; /**(Registered, Output feedback registered, Active low) **/
Pin 17 = o17; /**(Registered, Output feedback registered, Active low) **/
Pin 18 = o18; /**(Combinatorial, Output feedback output, Active low) **/
Pin 19 = o19; /**(Combinatorial, Output feedback output, Active low) **/
/** Equations **/
!o12 = o13;
o12.oe = vcc;
!o13 = o17 & o18
# o16 & !o18 & !o19;
o13.oe = vcc;
!o14 .d !i2
# i2 & !i4 & o14
# i2 & i4 & !o14;
o14.oe = OE;
!o15 .d !i2
# i2 & !i4 & !i5 & !o14 & o15
# i2 & !i4 & i5 & o14 & o15
# i2 & i4 & !i5 & o14 & o15
# i2 & i4 & !o14 & !o15
# i2 & i5 & !o14 & !o15
# i2 & !i4 & !i5 & o14 & !o15
# i2 & i4 & i5 & o14 & !o15;
o15.oe = OE;
!o16 .d !i2
# i2 & !i5 & o15 & o16
# i2 & !i4 & !i5 & o14 & o16
# i2 & i5 & !o16
# i2 & i4 & !o15 & !o16
# i2 & !o14 & !o15 & !o16;
o16.oe = OE;
!o17 .d !i2
# i2 & !i3 & i6 & o17
# i2 & !i3 & o17
# i2 & !i5 & i6 & o17 & !o19
# i2 & i3 & i5 & !o17
# i2 & i3 & !i6 & !o17
# i2 & i3 & !o17 & o19
# i2 & !i6 & !o17 & o19;
o17.oe = OE;
!o18 = i3 & o17
# !i3 & !o17 & o19;
!o19 = !i4 & o15 & o16
# !i4 & o14 & o16;- RichardT_altera4 years ago
Hi @CFabr1
I don't really get the PAL/GAL devices and its code. Unfortunately, we do not provide support on coding design.
Since you want to convert into sequential logic in Verilog, you may refer to the webpage below on how to do that.
https://www.allaboutcircuits.com/technical-articles/using-verilog-to-describe-a-sequential-circuit/
Or may search for other Verilog website that may helps.
Richard Tan
