SteveS109
1 year agoImplementing MIPI DSI-2 on an Agilex 5 device
I'm using the Agilex 5 FPGA E-Series 065B Premium Development Kit. There isn't much documentation - so I decided to generate the design example and run the simulation in Questa. I generated and ran ...
SteveS109
1 year agoSomehow the "Accept solution" button got mistakenly clicked. This issue is not solved yet. I blame the cat.
- Wincent_Altera1 year ago
Hi Steve,
Is okay, I have my cat who always come to my working table as well
Back to the topic, do you re-generate the design testbench after updating the parameter ?
If not , i would suggest to create a brand new one , I suspect is the previous run error causing current design corruption.
May I know which simulation tools and Quartus version that you are using ?
Regards,Wincent_Altera
