16 years ago --- Quote Start --- Hi, An interesting article, I guess you are the author. I understand that in principle there are only two types of reset: 1)synchronous reset(gated with data) and 2)asynchronous reset(directly connected to port of flipflops) It is also well-known that reset removal must be synchronised to its registers clock domain or else you will get problems especially as power-up differences of operation. I normally use a two stage synchroniser. The method explained in fig 16 of this article is interesting but I haven't tried it yet. However, the article doesn't define clearly the LAB-wide synchronous reset and it implies at times that it is not gated but I assume it is also gated. I looked at the 766 pages of stratix ii handbook and there was only one occurence of synclr which was in a diagram same as your diagram. There is no mention of chip-wide reset. I have never used it and I don't know it resets the firmware only or the configuration as well. For power-up reset, I can use internal counter that counts up to a maximum and stops and then I can do my reset work on its count values which yields a synchronous reset that is connected to asynchronous ports. As to external reset(synchronised or not), I believe in most cases it is waste of design since you can do a nice internal reset including power-up reset as mentioned above. Thanks for the article. --- Quote End --- Hi, Do the "reset removal must be synchronised " mean asynchronous reset input and synchrous reset output(or release)? Like below code implementations( and the attached block image): library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; entity Rst_Async2Sync is port ( clkin : in std_logic; async_rst : in std_logic; sync_rst : out std_logic ); end Rst_Async2Sync; architecture rtl of Rst_Async2Sync is signal Sync_rst1,Sync_rst2: std_logic; begin process(clkin,async_rst) begin if async_rst='1' then Sync_rst1 <= '1'; elsif clkin'event and clkin='1' then Sync_rst1 <= '0'; end if; end process; process(clkin,async_rst) begin if async_rst='1' then Sync_rst2 <= '1'; elsif clkin'event and clkin='1' then Sync_rst2 <= Sync_rst1; end if; end process; sync_rst <= Sync_rst2; end ;
