9 years agoImplement mux using for loop
Hi I think it is possible to implement a mux using a for loop like in the following example:
type array_type is array (7 downto 0) of std_logic_vector(15 downto 0);
signal mux_in: array...
9 years ago --- Quote Start --- The mux_out can be invalid for some mux_slct values if further in the pipeline this mux_out signal is not propagated in situation where mux_slct was "out of bounds". You still want to be able to test your circuit so you need a default value or the simulation will fail. --- Quote End --- You can use this to your advantage in simulation. The test fails, therefore there is an error in the generation of mux_slct.
