9 years agoImplement mux using for loop
Hi I think it is possible to implement a mux using a for loop like in the following example:
type array_type is array (7 downto 0) of std_logic_vector(15 downto 0);
signal mux_in: array...
9 years agoHi sstrell,
Thank you for your reply. I saw this construction working elsewhere and it is much better than a case statement aspecially when your mux start to be huge. It's already big just for MUX8 so imagine for MUX16 or MUX32:
signal mux_in: array_type;
signal mux_slct: unsigned(2 downto 0);
signal mux_out: std_logic_vector(15 downto 0);
p_mux : process(mux_slct,mux_in)
begin
case mux_slct is
when 0 => mux_out <= mux_in(0);
when 1 => mux_out <= mux_in(1);
when 2 => mux_out <= mux_in(2);
when 3 => mux_out <= mux_in(3);
when 4 => mux_out <= mux_in(4);
when 5 => mux_out <= mux_in(5);
when 6 => mux_out <= mux_in(6);
when 7 => mux_out <= mux_in(7);
when others => mux_out <= (others=>'0');
end case;
end process p_mux;
The first version contains less redundancy and is I think much more readable and code is better for maintenance. No idea why Quartus deosn't want to synthesise it as I want? Cheers
