Altera_ForumHonored Contributor18 years agoI'M puzzled. why simulation wave is incorrect! Hi. My design is a D FF. Its codes is as followed. When I simulate in the Quartus II 6.0 , the result of out1 is wrong and the result of out2 is correct. I am confused. I want to g...Show Morereg two chanel.jpg43 KB
Altera_ForumHonored Contributor18 years agoHello,Frank! You suggestion have help me a lot. Thank you again.
Recent DiscussionsAutomatically added negative node for TDS output doesn't work with Agilex 5Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SGDuplicate_hierarchy_depth / duplicate_registerQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerIs Quartus Prime Pro 22.4 Compatible with Stratix 10 NX Series Device 1SN21CEU2F55E2VG?
