18 years agoHi!
Thanks for your replay! Frank But my timing analyzer report don't indicate any timing violation. Timing Analyzer Sumary: slack Required time Actual time From To Worst-case tsu : 1.327ns 2.0ns 0.673ns in2[7] out2[7]~reg0 Worst-case tco : 3.047ns 9.0ns 5.593ns out2[7]~reg[0] out2[7] Worst-case th : 0.485ns 1.0ns 0.515ns out1[0]~reg0 If I change the code as follow all the output results in the timming simmulation are correct. I just add two input and two output and set the same timing assingments which have been set in the front code. module reg_four_chanel(clk,rst_n,in1,in2,in3,in4,out1,out2,out3,out4); input clk,rst_n; input[7:0] in1,in2,in3,in4; output[7:0] out1,out2,out3,out4; reg[7:0] out1,out2,out3,out4; always@(posedge clk or negedge rst_n) if(rst_n==1'b0) begin out1<=8'h00; out2<=8'h00; out3<=8'h00; out4<=8'h00; end else begin out1<=in1; out2<=in2; out3<=in3; out4<=in4; end endmodule The same structure of code and same timming assingment, but the simmulation is different. I also think the timing constrain should be assingment but which particular timing constrain should be assingment.
