I'm having trouble beginning any simulation in Quartus Prime 18.1
I've recently downloaded Quartus Prime Pro 18.1. I'm trying to get even a basic simulation started so I can work from there. I followed this guide here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_gs_msa_qii.pdf
And downloaded the example file, but I think this guide was written for a different version. For example, there is no Tools ➤ Options ➤ EDA Tool Options in my Quartus Prime. My Assignments ➤ Settings ➤ EDA Tool Settings ➤ Simulation looks quite different, and doesn't have the NativeLink section, so I can't start any simulation.
I can go to Tools ➤ Generate Simulator Setup Script for IP, but when I click it, I get this error message:
Error: 2019.01.17.18:10:20 Error: Device family cyclonev is not supported by ::quartus::sim_lib_info.
Are there any good step by step instructions on how to get started with the simulations?
- CalvinJoaz_P_Intel
Contributor
Hi Eric,
Good day.
Quartus Pro doesn't support the Native Links options but only in Quartus Standard.
Refer the previous thread with similar issue.
Thank you.
- ERagu
Hi Calvin,
Do I need to install the Cyclone V board?
- ERagu
Hi Calvin,
Contributor
Hi Eric,
Which device you're using? If you're using Quartus Pro, It doesn't support Cyclone V devices.
Refer link below.
Thank you.
- ERagu
The device I'm compiling for is a Cyclone 10 GX, so according to that it should work. I believe I'm getting the error because the simulator setup script is also trying to set up for the Cyclone V. Is there any way of altering that?
Contributor
Hi Eric, Apologize for delayed response. Kindly refer link below. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/ug_cyclone10_xcvr_phy.pdf Thank you.
