ERagu
7 years agoI'm having trouble beginning any simulation in Quartus Prime 18.1
I've recently downloaded Quartus Prime Pro 18.1. I'm trying to get even a basic simulation started so I can work from there. I followed this guide here: https://www.intel.com/content/dam/www/progr...
CalvinJoaz_P_Intel
Contributor
7 years agoHi Eric,
Which device you're using? If you're using Quartus Pro, It doesn't support Cyclone V devices.
Refer link below.
Thank you.
- ERagu7 years ago
The device I'm compiling for is a Cyclone 10 GX, so according to that it should work. I believe I'm getting the error because the simulator setup script is also trying to set up for the Cyclone V. Is there any way of altering that?
