17 years agoIgnored constraint
I've set a Tsetup and a Thold on a PLL because it's the PLL of the Altera ASI IP that I use in my project.
I've not seen when and why (I've upgraded to Q8 Sp1 some days ago) this assignement is ignored and the message I've is for example this one: " th Requirement 0 ns asi2rx2tx:inst58|asi_pll:inst1|sclk_pll_x50_4:inst2|c0 asi2rx2tx:inst58|asi_pll:inst1|sclk_pll_x50_4:inst2|c2 No element named dvb-t_mod_m was found in the netlist" I cannot understand why it ignore it. dvb-t_mod_m is the name of the top level of my project and the name of the directory. Suggestions? edit: I forgot to tell you that in Assignment Editor I've no error when I insert the constraint and after compilation they're ok (not with the "?" near).
